Replace front corner turn signal bulb
Old May 15, 2009 | 02:33 PM
crosby1's Avatar
Default Replace front corner turn signal bulb
hi, how do you access the front signal bulb on the '01 s40? i can't get to it from inside the engine compartment...now i'm @ a loss.
thanks very much....
Old May 15, 2009 | 02:50 PM
superbovine's Avatar
There is a Phillips screw located in the corner behind where the housing and the headlight meet, pointing down.
Unscrew it (it stays in place once loosened) and slide the marker light forward.
Old May 15, 2009 | 03:44 PM
crosby1's Avatar
hi. thanks. what housing do you mean? the headlight housing? is the screw accessible from inside the engine compartment?
thanks again.
Old May 23, 2009 | 01:15 PM
crosby1's Avatar
got it. thanks. the screw in question is just to the outside of each headlight.
Old Apr 15, 2010 | 08:17 PM
Armen_Tamzarian's Avatar
Thank you so much! Having this exact problem and was getting a headache over it. Much appreciated!
Turbo_Boss
May 4, 2022 12:39 PM
LandonJBennett
Jun 6, 2011 12:23 AM
davej
Apr 22, 2011 08:47 AM
rfmommy
Jun 26, 2009 07:54 AM
Linksman
Mar 2, 2008 07:09 AM
