A/C Drain -can't find
Old Jun 30, 2009 | 10:50 PM
xc902006's Avatar
Default A/C Drain -can't find
I recently had the filter changed on the car and it appears the plastic cover was damaged and it is now leaking. I looked for the drain to make sure it wasn't plugged, but I am not sure I found it. The plastic cover for the filter has what appears to be a hose connection for a drain, but it doesn't do anything. A lot of water comes out from the plastic cover. There is a 1/2" or 5/8" hose to the right of this that is not blocked, but it sits higher than the filter cover --- Is this the a/c drain?
Does anyone know if this is to be expected and exactly where the drain is?
Old Jul 3, 2009 | 08:01 AM
The drain should be under the drivers side. Remove the lower dash panel. Then there should be a hose that goes from the white case into the firewall. That should be the drain.
winarabbit
Jan 12, 2014 09:32 PM
danni
Sep 17, 2013 11:56 AM
jbarnes
Jun 12, 2013 11:46 AM
Brennan.Messick
Sep 19, 2011 03:06 PM
danni
Oct 11, 2003 03:56 PM
