Water Leak From Center Console (passenger side)
Old Jul 13, 2009 | 02:13 PM
pr1229's Avatar
Default Water Leak From Center Console (passenger side)
Noticed that passenger side carpet was wet so removed it to dry and look for source of leak.
I have isolated the water source to the passenger side/center console area. The water only drips when the A/C is running.
Does anyone know how to correct this or what the cause could be? Any help would be greatly appreciated. Thanks!
Old Jul 20, 2009 | 01:26 PM
gplourde's Avatar
Default Water Leak
My daughter is having the same problem. I just posted the same question for her. No answers yet.
Old Jul 21, 2009 | 09:07 PM
pr1229's Avatar
I am still at a loss. It seems that the water is dripping from the lowest point on the heat exchanger. However, I am unable to determine the source.
Have you (or anyone) had any luck resolving this?
Old Jul 22, 2009 | 06:48 PM
A/C drain clogged? I have seen that before and it is on the passenger side. I had a car today that the sunroof drain was clogged and blew the hose off and was leaking into the car.
Old Jul 23, 2009 | 01:29 PM
DOHCRT's Avatar
This seems to be a common sign of a clogged A/C drain tube. The drain is located on the passenger side of the exhaust tunnel. Ive had a couple of theses cars with the same problem.
Old Oct 18, 2009 | 08:12 PM
tracy4419's Avatar
How do you fix this problem? Does anyone have pictures of the AC drain Tube and where it is located exactly and how to get to it? I am having the same problem with my rugs being wet. Please help!
mrgreen
Apr 2, 2015 08:08 PM
wavolvo
Oct 24, 2010 04:57 PM
reidjw
Nov 16, 2008 08:49 AM
stefalfonso19
Jul 22, 2008 03:02 PM
Qamar
Nov 14, 2005 12:53 AM
