01 S-80 Interia water leak passenger side front
Old Nov 8, 2008 | 04:23 PM
reidjw's Avatar
Default 01 S-80 Interia water leak passenger side front
When it rains, I get flooded. AC/Rec settings have no effect. The sunroof is not the source. The windshield is the original. The dashboard was replaced as a result of airbag deployment sometime ago. Has anyone had this problem or a possible solution?
Old Nov 9, 2008 | 06:58 AM
Default RE: 01 S-80 Interia water leak passenger side front
Does the car have a sunroof?
Old Nov 9, 2008 | 10:33 AM
reidjw's Avatar
Tech, the drains for the sunroof have been checked so I am assuming that they are clear. As for the (2) drain pipes, is there a connection (screws) at the top of the channel that have to be disconnected if I attempt too remove the pipes from below the car?
Old Nov 9, 2008 | 10:44 AM
I haven't had them apart in a really long time I believe there is something securing them on the bottom.
Did the drain hoses get inspected from inside the car? (A-pillar under the panels)?
Old Nov 9, 2008 | 11:21 AM
reidjw's Avatar
OK, I used my blower from the top on both sides and the flapper valves at the bottom of the tubes opened and nothing came out. If I lift the cowling grill from the top by the windshield, I believe what I'm seeing is the cowling seal loose. Question is, how do I remove the wipers?
Old Nov 9, 2008 | 08:17 PM
Its been a while I think there is caps that fold up. I will try to check more tomorrow. I cannot access my Vadis right now.
Old Nov 15, 2008 | 08:15 PM
reidjw's Avatar
Tech, still waiting too see how the wiper blades are removed. True you lift the cap and a you remove the nut, but does the blade lift off or is it screwed on? It doesn't lift up easily at all. OBTW, I ran tape across the cowling and the windshield and my car is bone dry after several heavy rainfalls. I've got to get to the cowling seal...
Old Nov 16, 2008 | 08:49 AM
Once the nuts are removed then press down on the center of the wiper arm area. It gets pushed down on a cone shaped splined shaft off the wiper assembly. So press in the middle of the arm some till it pops loose.
mrgreen
Apr 2, 2015 08:08 PM
joshuapfitzpatrick
Jun 25, 2012 10:57 AM
wavolvo
Oct 24, 2010 04:57 PM
jlb1181
Apr 8, 2010 08:35 PM
pr1229
Oct 18, 2009 08:12 PM
