Passenger side water leak
Old Dec 4, 2008 | 10:28 PM
wavolvo's Avatar
Default Passenger side water leak
I have a passenger side water leak in the rain.No AC is on. It seems to be dripping down from above near the right corner. Any ideas?
Old Dec 4, 2008 | 10:48 PM
C70_Guy's Avatar
Default RE: Passenger side water leak
Sounds like the sunroof drain could be clogged. The A-pillars would have to be disassembled and check to see if the drainage hoses are open and clear of debris.
Old Dec 5, 2008 | 08:31 AM
Yes it is a very poor design by Volvo. The drains usually get clogged and the hose pops out of the rubber elbow then it continues to leak inside of the car instead of draining onto the ground.
Old Oct 20, 2010 | 11:56 PM
sporttourfjr's Avatar
sunroof drains are a maintenance item.. you can check yourself and clear with light air pressure... you expect Volvo to warranty against leaves,dirt, and chewing gum!
Hey I just heard a boatload of trial lawyers just sank!
Old Oct 24, 2010 | 04:57 PM
mine are good all the way to the driveway.... took 3 minutes and 16 ounces of water
mrgreen
Apr 2, 2015 08:08 PM
pr1229
Oct 18, 2009 08:12 PM
reidjw
Nov 16, 2008 08:49 AM
stefalfonso19
Jul 22, 2008 03:02 PM
Qamar
Nov 14, 2005 12:53 AM
