Fuel injectors
Old Aug 10, 2009 | 03:51 PM
Spey's Avatar
Default Fuel injectors
Hi all,
Does anyone know if the fuel injectors are interchangable between a '94 850 2.5 20v and a '96 850 2.5 20v. I removed a set from a '94 in a breakers yard and sent for clean/test, had a quick look at mine today to get tools together for change and realised that the injectors seem differant...doh!!
The ones that i have currently got fitted are the yellow ones.
Cheers
Mark
'96 850 2.5 20v GLT
Old Aug 10, 2009 | 05:15 PM
VJZ's Avatar
VJZ
We don't have a 2.5 in the States but I would imagine they are
Old Aug 10, 2009 | 07:21 PM
redbottle's Avatar
Default Injectors
The yellow ones are capable of 198.99mm I guess, or something like that. My 850 Turbo has 300.00mm, the orange looking ones, they are a bit fatter than the yellow ones, or they might be a weird orange. If anything you might not get the response as usual, maybe slower but normal?
Old Aug 11, 2009 | 12:37 PM
fcpgroton's Avatar
Former Sponsor
As long as they are the same impedance, they will work.
Old Aug 11, 2009 | 01:42 PM
Impedance??? What's that mean?
What I usually do to see if one model has parts that will work on another year model is go to a parts website. Look up a part for the car I have, then look up that same part for the car I want to take parts from. If the part numbers are the same, it will likely work. If not, then I move on.
Old Aug 12, 2009 | 09:34 PM
redbottle's Avatar
Impedance: noun, a material's opposition to the flow of electric current; measured in ohms uhhhhh...no hablo science.
Old Aug 13, 2009 | 09:10 AM
fcpgroton's Avatar
Former Sponsor
LOL, there are two kinds of injectors, Low Impedance and High Impedance. The low Impedance are found on the 940 Turbo as an example and have a resistance of only a few Ohms. The 850, and the non turbo 940 have what is know as a high impedance injector, which is around 50 Ohms.
Old Aug 14, 2009 | 12:04 PM
Saleen9090's Avatar
I understand impedences because I have dealt with so many speaker wirings. Just wonderin why the differences in impedences between the two? I know lower impedences tend to be unstable and can cause problems but in benefit require lower current to power.
pinegrovedave
Apr 21, 2014 01:44 PM
Vmax
Apr 7, 2014 07:42 PM
J Taylor
Apr 12, 2006 09:31 PM
robmcconnell
Nov 6, 2005 09:25 PM
240GL38751
Aug 5, 2004 03:25 AM
