Oil
Old Oct 19, 2009 | 07:30 AM
nclair's Avatar
Default Oil
Hey up, i have a new shape S40 volvo, 2.0 D 2005, what sort of Oil do i need, i need change it, i've ask number of people and i got different answers.
Thank you.
Old Oct 19, 2009 | 08:14 AM
Somthngfrce's Avatar
You will ALWAYS get a different answer with this question! It's such a subjective topic. Really, if you have a turbo car, you should be using synthetic but some folks use fossil oil. Personally, I used to use Castrol Synthec 5w30, but just switched to Lucas Synth 5w30. I believe Volvo recommends changing synth oil every 5k. Most of us, including one or two techs that are part of the forum will tell you change it every 3,500-4k as added insurance! Every dealer also uses different oils, they just stick with the same weight depending on the vehicle, so with that said, find an oil YOU like and the important part is to stick with the interval change! That will guarantee your car and seals to max longevity. Some of the Oils that are good are Castrol, Royal Purple, Lucas, Amsoil, Valvoline. Also I recommend using a OEM Volvo oil Filter since they have a check valve built in. Some of the aftermarket filters may not have....
Old Oct 19, 2009 | 08:28 AM
Johnny Mullet's Avatar
The oil filter is a cartridge style and you will need the proper socket to remove the lid. Any Turbo car should get 3,000 mile oil changes.
Old Oct 21, 2009 | 07:40 AM
nclair's Avatar
Thank you, i was thinking using Castro Magnatec, once again thank you for your help
Old Oct 22, 2009 | 06:48 AM
VolvoS40S60's Avatar
Exclamation
I have a 2003 S40 & use Mobil 1...fully synthetic....car engine runs smooth...I change the oil every 3000 miles.... good luck....
nuclearseal
Aug 17, 2022 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
nationm
Feb 12, 2006 10:09 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
