Front wheel vibration
Old Oct 19, 2009 | 12:39 PM
jakebelder's Avatar
Default Front wheel vibration
Hey all, I just bought an '88 240 DL. Proud to be a Volvo owner! I have one thing I need to fix on it, however. Around 45-50mph I start to get a pretty intense vibration in the right-front wheel. Now, it does need new tires up front as well as an alignment, so I plan to get that done and am wondering if that would fix it.
But I think it might be something more, and I'm having trouble diagnosing what that might be. I had it up on jackstands the other day, and there is some play in the wheel. But I can't figure out if that means it is the ball joints, tie rod ends, or wheel bearings. As far as I can tell, it could be any of them (although, I don't have any grinding noise or anything so maybe not the bearing?).
So should I just get the tires and alignment and see what happens? I'd kind of like to figure out if it's more because if I then have to replace, say, the ball joints, I'm going to have to shell out for another alignment. Any advice?
Old Oct 19, 2009 | 12:45 PM
bubba240's Avatar
You might want to swap the fronts with the backs and see if it follows the tire.
Old Oct 19, 2009 | 07:25 PM
jakebelder's Avatar
Thanks for the tip. I did that tonight. Also noticed that the tie rod ends are pretty worn, so I'll be ordering replacements.
Old Oct 20, 2009 | 03:55 AM
Typhoon's Avatar
I was just about to type tie rod ends. They can make wheels that are tolerably well balanced behave like unwieldy monsters.
Regards, Andrew.
badrabbit
Aug 2, 2011 04:07 PM
jasonk1973
Nov 26, 2010 08:53 AM
300K740
Dec 10, 2009 09:13 AM
ocean238
Apr 17, 2008 06:20 PM
ludeless
Nov 26, 2005 09:32 AM
