Caulk for tailgate hinges
Old Sep 7, 2007 | 10:51 PM
blue goose's Avatar
Default Caulk for tailgate hinges
I'll be replacing the tailgate wiring harnesses shortly. Just making sure I have the materials. The "Volvo Problem Solver" says to make sure the bolt and wire harness holes are properly caulked. OK, what caulk? Silicon? Permatex? Thanks.
Old Oct 18, 2009 | 11:30 PM
Sambar Stag's Avatar
I did the tailgate hinge replacement/wiring harness bit myself a while ago. When my 16 y/o son and I took off the hinges , the "caulk" that was there looked just like plumber's putty that had hardened a bit over the years. So that's just what we used, plumber's putty that you can get at any home store. So far, no leaks, corrosion or paint damage. RTV Silicone would be my next choice, but the putty also worked well in holding the washers/spacers in place that need to be held in alignment to replace the bolts.
Old Oct 20, 2009 | 03:58 AM
Typhoon's Avatar
You can use windscreen sealer (not windscreen adhesive) for this. It never truly sets so remains flexible and is easy to clean up.
Regards, Andrew.
boozaman
Jul 9, 2010 12:22 PM
ShaginWagon
Apr 12, 2010 04:02 AM
DeFoaBuSe
Mar 22, 2008 04:25 PM
likesspace
Jun 23, 2007 04:32 PM
daver80
Oct 5, 2006 11:53 PM
