760 turbo - Engine over revving?
Old Nov 5, 2009 | 03:45 PM
kylebooth's Avatar
Default 760 turbo - Engine over revving?
hey, i have a 84 volvo 760 turbo. Its a automatic transmission. Latly it hasnt been shifting properly. when i press down on the gas pedal it revs high than decides to shift causing me to accelerate slow. My instrument cluster is also having some issues ( i dont know if this has anything to do with the problem) but the gas gauge seems to only work once in a while and the spedometer only works sometimes. I have no dash lights either, i replaced the bulbs and checked the fuses and they still dont work. I dont know a whole lot about cars but i can fix almost anything when i know what the problem is. Does anybody have any ideas? Thanks alot.
Old Nov 11, 2009 | 10:53 AM
tedv's Avatar
Both are not related. The late shifting could be caused by a bad throttle cable--check that it doesn't bind or has too much slack. Or may be the trans needs a fluid change (every 30K). The electrical gremlins may be due to rotten wiring harness, bad grounds or a bad instrument pc board.
Old Nov 14, 2009 | 05:41 PM
kylebooth's Avatar
Thanks for the reply. how do i know how much slack the throttle cable should have?
maddox
Jun 19, 2009 07:06 PM
Bruce Wayne
Apr 3, 2009 11:10 PM
kpmaca
Jul 28, 2008 08:18 AM
maddog
Jun 19, 2008 07:21 AM
trhillar
Oct 18, 2005 09:32 PM
