MAF/ETM advise needed
Old Nov 6, 2009 | 01:58 PM
slance66's Avatar
Question MAF/ETM advise needed
Hi, I have a 2001 S60, non-turbo. 109k+ on the odometer. I've had my ETM cleaned, most recently about a year ago. Hunting at idle persists, and is sometimes accompanied by a shudder in the steering wheel. On one occasion recently, I had more severe problems at speed, with random deceleration and a rough running engine. Thinking that my ETF was finally about to send me to limp home mode, I visited the dealer.
No codes were found. Dealer confirmed symptions and performed a "potentiometer test" of the throttle, which it passed. They then found that my MAF sensor is "reading out of range". I rejected the suggestion to replace the MAF for $475 (Part is online for under $200). I cleaned the MAF and it has improved slightly.
I'll probably sell this car soon. I want to know whether it is likely that the MAF is really the problem here, and whether replacing it, $200 out of pocket, will "fix" this problem beyond the minor improvement I got by cleaning it. If it makes the car run smooth and idle perfectly, the investment may help me sell. If not, I'll never get it back (which is probably true of the $390 I just paid for lower control arm bushings as well). Any thoughts on whether "reading out of range" means that my MAF is done? Is this "potentiometer test" legit, or a way to avoid paying for an ETF under the extended warranty?
Old Nov 6, 2009 | 02:32 PM
Bender's Avatar
sounds like your MAF is dead - ETM is not clear...
Old Nov 10, 2009 | 07:51 AM
slance66's Avatar
Any other thoughts? Is the MAF definitely toast? Car mostly runs pretty well, and my mileage has been good.
Old Nov 10, 2009 | 11:02 AM
Bender's Avatar
can't say anything for sure without physically getting my hands on the car - i would take it for a second opinion.
johnmal85
Jul 23, 2014 07:36 PM
ajbpoplpo
1998-2000 model year V70
Jun 27, 2013 09:50 AM
Fuzzykb001
Jul 30, 2011 10:10 PM
AlextheKiwi
Feb 12, 2011 02:48 AM
jsav4589
Aug 1, 2010 10:32 PM
