mass airflow sensor
Old Nov 15, 2009 | 03:23 AM
c70turbogt's Avatar
Default mass airflow sensor
Hey guys. It has been a while. I need some advice. My car wont start up. The engine cranks but it does not sustain. The computer indicates a mass flow sensor problem. Any advice?
thanks,
akg
Old Nov 15, 2009 | 07:07 AM
If the mass flow is bad and will not allow the car to start and you unplug it the car should start.
Old Nov 16, 2009 | 12:59 AM
c70turbogt's Avatar
Default Mass air flow sensor...
Could you please tell me where its located so I can pull it out?
akg
Old Nov 16, 2009 | 01:09 PM
mkc70's Avatar
akg
It is connected to the air box filter housing, on the drivers side. Electrical plug is right on top of the meter. Looks like this:
http://www.fcpgroton.com/product-exe...category_id/10
Old Nov 16, 2009 | 04:34 PM
reg's Avatar
reg
be advised that your fuel mileage will be affected and I am sure you will start 'throwing' additional codes. replace the MAF ASAP. CRC makes a product that 'cleans' the MAF although I doubt it would bring life back to your present MAF. It is a good product to prophylactically clean your MAF annually.
r
Old Dec 2, 2009 | 01:55 AM
c70turbogt's Avatar
Default Electronic throttle module
hey....
I had my dad pull the maf out as i am out of the country. It still didnt start up. Do you think it is the Electronic throttle control module? If so is it still covered under warranty....my car is a 99.....can someone use the vin to check for me?
Old Dec 2, 2009 | 07:55 PM
If it was the throttle body there would be codes stored for the ETM.
Old Dec 3, 2009 | 01:04 AM
c70turbogt's Avatar
Default ???
any suggestions what it may be?
thanks guys!
Old Dec 3, 2009 | 07:04 PM
The basics need to be checked. Fuel,spark, injector pulse.
Old Dec 8, 2009 | 01:26 AM
c70turbogt's Avatar
Default advice.
So you think it might throw an maf code even if its not the maf?
thanks
akg
Old Dec 11, 2009 | 08:51 PM
A vacuum leak will throw a MAF code as well.
Old Dec 14, 2009 | 02:04 AM
c70turbogt's Avatar
Default question.
will a vacuum leak affect the car starting up?
Old Dec 15, 2009 | 08:46 PM
Not really. But ti will throw a code.
Old Feb 11, 2010 | 11:12 PM
mikeross's Avatar
Yeah I agree. You should be replacing the mass air flow sensor immediately. I had a similar problem before and I did not replace it for about 3 months then there was some knocking, pinging, stalling and shuddering of the car.. really bad..
TLWR
Sep 10, 2023 10:56 AM
maren36
Apr 3, 2010 05:35 PM
jdubya
Feb 28, 2010 03:46 PM
chachouu
Oct 5, 2009 04:31 AM
cbrack
Jul 27, 2008 10:55 AM
