firing sequence?
Old Nov 16, 2009 | 02:18 PM
s_moneh's Avatar
Default firing sequence?
ok so i took the t5 out for a spin today and noticed a HUGE sputter, liek i would idle and it would shake the whole car, soi'm like hmmm after about 10 min of driving time the check engine light came on, so i went ahead and checked it out
p0304- cylinder 4 misfire
p1310- no idea....
so i'm wondering which is the right cylinder to look at?
i replaced the plugs and cables with NGK
ngk wires
ngk iridum plug
they r brand new and i dont know why is misfiring, i'm begining to think i may have messed up how i plugged it into the distributor cap
so i'm jsut wonder which cylinders r which? and wats the right placement for the distributor cap thanks!
Old Nov 16, 2009 | 02:23 PM
get rid of those plugs. only use oem plugs. I have read stories of people who had misfires, swapped their aftermarket plugs for oem ones, and the car ran perfect afterward.
Old Nov 16, 2009 | 02:42 PM
s_moneh's Avatar
honestly tho i had these same ones in my other 850 and it ran BEAUTIFULLY never had a problem with the same plugs, mind u they were 11$ a piece i tihnk i may have done somthing along the lines of replacing them and thats wats giving me a cylinder 4 misfire
wat is the order for the cylinders? and where does each cylinder plug into the cap? can anybody give me that?
Old Nov 16, 2009 | 02:58 PM
blackbrick's Avatar
here !
Old Nov 16, 2009 | 05:59 PM
Oh really? I've read a lot about people running those and misfiring all the time, then switched back to oem and everything was fine. More power to you, and for 11 bucks a piece, they better give your car wings.
Old Nov 16, 2009 | 11:04 PM
s_moneh's Avatar
so i came home from work not to long ago and began my investigation, and i've come up short.... the can ran fine wen i got home, no sputter, no codes nothing, however i did check each adn every spark plug and it seems the my cylinder 4 may not be getting fuel, i'm gunna have to further test that out tommorow, but wats my best option on doing that?
Old Nov 16, 2009 | 11:28 PM
blackbrick's Avatar
HTML Code:
I'm not expert but this is what I would do:
When engine running spray some injector or brake cleaner around injector, if it sucks in then it needs new O ring. If not, switch injector 4 and 5 and see if it misfire in cylinder 4 or 5. If misfire in 5 then its bad injector, if misfires in 4 then it is electrical.
Indy S60
Oct 19, 2023 12:05 AM
pdieni
Dec 18, 2010 01:19 PM
xjflexer
Jun 19, 2010 03:38 AM
daver80
Oct 23, 2007 04:55 PM
gwoodall
Jul 7, 2006 10:35 PM
