volvo 850 instrument panel problem
Old Nov 18, 2009 | 09:17 PM
chadman551's Avatar
Default volvo 850 instrument panel problem
i have a volvo 850 and a while ago the gauges on the instrument panel wouldn't work when i started it right away then they would work after a few seconds, but when i started driving they would go off and not work unless i was stopped and the orange gear indicator arrow was flashing. this problem went away for a few weeks then just started again, how can i fix this and what could be the problem?
Old Nov 19, 2009 | 02:15 AM
The flashing arrow "indicates that there is a fault in your automatic gear box": https://www.customers.volvocars.com/....html#controls This happened to me when I was driving with the shifter no in the right gear. I was between D & 3. When I got home, I cleared the code with my scanner and all was well.
Not sure about the dash gauges.
Old Nov 19, 2009 | 10:36 AM
fcpgroton's Avatar
Former Sponsor
If your car is a 94 or a 95, you can check the gauge cluster codes under the hood. The port is A7 for the gauge cluster codes.
theflemingcrew
Oct 12, 2011 02:58 PM
lama850turbo
Oct 25, 2010 07:17 PM
jrcochranusa
Feb 19, 2010 02:30 PM
alexortiz83
Jun 26, 2006 09:31 PM
jlc_740GL
May 29, 2006 06:07 PM
