Right Turn Signal Failure Indicated
Old May 27, 2010 | 11:54 PM
KeithS60&V70T5's Avatar
Default Right Turn Signal Failure Indicated
I have replaced both front and rear bulbs and it still is blinking fast and giving me bulb failure message. Both bulbs, even the side marker are working fine.
After replacing the front right bulb, it went to a slow flash and everything seemed okay. Then almost right away it went back to quick flash and failure notice.
Any ideas of what the problem may be?
Last edited by KeithS60&V70T5; May 28, 2010 at 01:40 AM. Reason: corrected description
Old May 28, 2010 | 07:43 AM
SVTfocusO3's Avatar
the sockets!!!!
Old style are white
new style are brown.
part # 8662985
Old May 29, 2010 | 08:13 PM
RollyTG's Avatar
I have the same problem. Levering the socket forward seems to fix it temporarily but there is no way to hold it forward so it just reverts to the fast flash and the bulb failure message. How much do replacement sockets run?
Old May 30, 2010 | 05:06 PM
SVTfocusO3's Avatar
$18 dealer.
Old May 30, 2010 | 07:19 PM
RollyTG's Avatar
Thanks for that. Our dealer told us we had to replace a controller for $200 +. $18 sounds a lot better.
Old May 31, 2010 | 01:43 AM
Thank you. While I am at it I will see about replacing the brittle and broken, but yet somehow still working, headlamp connectors on my other S60 and V70 as well.
Old Jun 1, 2010 | 12:40 PM
SVTfocusO3's Avatar
OH, volvo has a problem with those, but you can order just the socket from them and splice it in. You dont have to remove the headlight, they will charge you for it though (dealer).
Old Jun 5, 2010 | 05:51 PM
Default Problem Solved!!
Part # 8662985 Did the trick. It came with a bulb for $11.00 at Sanderson Volvo in North Phoenix.
Thank you SVTfocus03
Old Jun 10, 2010 | 04:39 PM
RollyTG's Avatar
Default Turn signal problem
Job's right. Total cost $20. Thanks folks.
marvgt95
Aug 30, 2024 01:18 PM
suckonthiscaravan
Dec 5, 2018 03:19 PM
jasonthaynes
Dec 2, 2012 05:32 PM
GentleBen82
Oct 9, 2012 08:37 AM
polka salad
Jan 18, 2008 09:40 AM
