right side turn signal stays on
Old Dec 17, 2009 | 06:45 PM
marvgt95's Avatar
Default right side turn signal stays on
so none of my lurn signal was working so i replaced the fuse and the left work great but the right just stays on they dont blink just stays on even if i turn the car off the front side and back blinker wont go off this only happens to the right side of the car
Old Dec 18, 2009 | 01:43 AM
Goat's Avatar
That doesn't sound good. Electrical issues scare the bejeezus out of me. Sounds like a shorted relay or switch... Perhaps some long time Volvo owner has experienced this with a Volvo and knows where to start, sorry to say, that's not me. Good Luck.
- Goat
Old Dec 18, 2009 | 03:17 PM
JTapper's Avatar
Try swapping out the relay with a known good one. If that solves the problem, all you need is a new relay. Common failure with age.
Old Dec 19, 2009 | 07:55 AM
Make sure the bulb is not bad.
Old Dec 28, 2009 | 12:16 AM
marvgt95's Avatar
replaced relay with good one and it did not work and bulb is good plus i dont think none of those will keep the lights on
Old Dec 28, 2009 | 08:22 PM
I would check the socket and wiring leading to the socket.
Old Jan 1, 2010 | 05:04 PM
marvgt95's Avatar
tried all that nothing is working even tried hazard switch
Old Jan 1, 2010 | 05:06 PM
SO no power at all?
Old Jan 3, 2010 | 03:01 PM
checksix's Avatar
Sounds like a grounding issue for another nearby circuit, that is using the turn signal as a ground, thus it is on all the time.
Jerry
Old Aug 29, 2024 | 12:25 PM
Sokka7123's Avatar
Default Same issues !
Ever figure out the issue?
Old Aug 30, 2024 | 01:18 PM
15 year old post... Diagnostics advise is the same however - check the relay then check power and ground points
suckonthiscaravan
Dec 5, 2018 03:19 PM
Jkherw
Jun 30, 2013 02:19 PM
GentleBen82
Oct 9, 2012 08:37 AM
KeithS60&V70T5
Jun 10, 2010 04:39 PM
polka salad
Jan 18, 2008 09:40 AM
