A/C Compressor won't turn off-1993 240
Old Jul 24, 2010 | 03:41 PM
newmex999's Avatar
Unhappy A/C Compressor won't turn off-1993 240
The a/c compressor will not turn off, here is what I have done so far:
I unplugged the green wire going to the compressor and it turns off
Plugged green wire back in and unplugged a/c relay and compressor is still on!! I know what you are thinking-must have the wrong relay?-however the relay I unplugged has wires going into it from both the blower motor switch and the a/c switch on the dash so it's gotta be the one.
I then unplugged wires from a/c toggle switch on dash as well as unplugging the connector from the back of the blower motor switch, fuse #12 and brown connecter under hood behind receiver/drier unit and compressor is still humming away!
If I unplug the connector from the high pressure switch on top of the receiver/drier then the compressor turns OFF.........
What next
volvoralph
Jul 19, 2016 04:19 PM
angusjustice
Apr 11, 2014 09:38 PM
RikoOrtiz
2001-2013 model year V70
Dec 17, 2013 03:47 PM
chrismc410
Aug 24, 2013 06:38 PM
Heras
Apr 27, 2010 11:47 AM
