S40 Broken Timing Belt (posted in August 2010)
Old Aug 13, 2010 | 12:56 PM
Mro111's Avatar
Default S40 Broken Timing Belt (posted in August 2010)
So my A/C belt broke and some how managed to wrap itself onto the Timing Belt and pully and broke my Timing belt. I installed a new belt and ligned up my marks correctly and started it up. My car now sounds like its out of timing sputters and just sounds crappy. I turned it off and re-checked my timing marks to make sure everything was still ligned up and it is. Im afraid i now have valve damage. My question is this job a difficult job or should i turn it over to a Volvo Specialist and sink in lots of $$$
is there anything special or different then other cars for this repair??
What should i look for? What should i ask the Mechanic?
Any help would be greatly appreciated.
Thanks!
Old Aug 31, 2010 | 09:30 PM
zachy's Avatar
Unfortunately if your engine is interference then you can bet you've bent valves. Sorry guy but you need to do a compression test to locate the damaged cylinders then pull the head and replace the valves.
Old Sep 2, 2010 | 02:07 PM
Mro111's Avatar
Default Your Correct
Zachy,
unfortunately for me you are correct. My car is in the shop. After the Mechanic pulled the head i had him call me so i could get a visual on the bent valves and sure enough they were bent.
Now i know not to let my A/C belt go without being changed.
Ive read on some other posts where the magnets go bad on the A/C compressors and over heat and release the clutches and your
A/C kicks off.
is this accurate?
Old Sep 2, 2010 | 06:09 PM
SVTfocusO3's Avatar
Year!!!
Old Sep 4, 2010 | 08:28 PM
zachy's Avatar
I think that is possible. The windings break, go open, and the clutch will not engage. The connections are easily testable. Just use an Ohm meter and test the continuity. It should be about 2 to 5 ohms. Any more and it will need to be replaced. If the resistance is okay you can have a problem with the clutch. The spacing could be too wide. That is easily tested. with the coil energized just push against it. if it sticks to the pulley, just re-space it.
Old Sep 7, 2010 | 02:26 PM
Mro111's Avatar
Hey, i like that idea
Thanks!
gasp
Nov 17, 2010 07:16 AM
wieder
Sep 10, 2010 08:42 PM
turbo940v
May 2, 2010 12:32 PM
pinkyjabberbox
Apr 25, 2010 08:06 PM
01S60
Mar 29, 2010 10:01 AM
