740 GLE Fuel pump in 760 Turbo?
Old Aug 14, 2010 | 10:41 PM
BassGuy's Avatar
Default 740 GLE Fuel pump in 760 Turbo?
I'm looking into purchasing an '85 760 Turbo, but the seller said they suspect the fuel pump for the car not starting. It turns over otherwise.
My parents have a 740 parts car that I'm sure I could scavenge off, if this works.
Has anyone done this before (successfully)?
Old Aug 15, 2010 | 10:19 PM
swiftjustice44's Avatar
It depends on the parts car. If the parts car is a Regina ignition car it only has one fuel pump, in tank. If the p/c is a Bosch ignition then the pumps are essentially the same. The only replacement pump available today is the n/a/ variety. The turbo fuel pump is a little higher volume, but unless you're making super boost, the n/a is fine.
Old Aug 17, 2010 | 01:13 AM
BassGuy's Avatar
How would I go about finding that out? There's been an '88 740 GLE in the family for about 10 years, but I'm not too sure on the specifics of the parts car.
The N/A pump would be fine to get the car running/on the road? (assuming it's the Bosch style, as you said)
Old Aug 17, 2010 | 06:46 AM
If it's a Regina ignition, it will have an HEI coil on the driver's strut tower rather than a conventional cylindrical coil. Here's a Regina motor...
Yes, the n/a pump will work for the turbo. That's all you can buy today, anyway. You would need to be making 220-250 hp to the rear wheels before the stock pump would be insufficient.
Modern fuel systems like the Volvo provide way too much gasoline to the fuel rail in an effort to assure sufficient fuel under all circumstances. The fuel pressure regulator sets the pressure; any fuel unused by the motor simply returns to the gas tank until it gets slurped up again. There is no mystery to fuel pumps; they are no more complex than an aquarium pump. They all look similar...the difference is volume pumped (Liters/Per/Hour or Gallons/Per/Hour) and max pressure before the pump motor stalls (remember, it is the fpr that sets the ultimate pressure at the engine). There are 2 types of pump locations, basically. Inline (under car) and in tank. In a 2 pump system the tank pump is usually smallish and is merely a lift pump to get the fuel out of the tank. Then, the larger, more powerful pressure-wise inline tank cranks the pressure way up for the trip to the engine. In a 1 pump system, the fuel pump is generally in the tank and pulls double duty as a lift AND pressure pump. That's how the Regina cars are...one pump in-tank. Any number of in-line fuel pumps can be used on Volvo turbos...the ultimate IMHO, is the Bosch 044 pump. It takes a little modding but has super volume and pressure figures. A Walbro 255 lph model or even a 190 lph model would satisfy fueling requirements well past 300 whp. In a highly modded set up, there would be a 255lph lift pump in the tank and TWO fuel pumps under car. But...not for a DD grocery getter!!
Old Aug 19, 2010 | 08:44 AM
BassGuy's Avatar
Thanks! That helps.
Old Aug 25, 2010 | 12:56 AM
BassGuy's Avatar
Would old fuel keep the car from starting? Apparently it's been parked for 2 years.
Old Aug 26, 2010 | 07:04 AM
Default old fuel?
Oh yeah...always good to pull a tank hose before you begin...stale gas is bad enough but I've seen one year old gas that was brown and very cloudy w/ rust/contaminant particles.
Old Aug 27, 2010 | 07:51 PM
BassGuy's Avatar
Thanks. I actually found a running 760T that I'm purchasing.
Old Aug 27, 2010 | 08:06 PM
Sweet! That simplifies things!!
Old Aug 28, 2010 | 08:52 PM
BassGuy's Avatar
Definitely. It's an 86, 764T with 300k KM.
blissbrick
Mar 7, 2015 05:25 PM
MondoBach
Jul 1, 2012 07:53 AM
steelheaddan
Feb 5, 2011 06:54 PM
Qamar
Sep 4, 2005 02:06 AM
crazypixie
Jan 22, 2005 01:01 AM
