1988 volvo 740 turbo with no spark
Old Aug 25, 2010 | 06:06 PM
brettyg123's Avatar
Default 1988 volvo 740 turbo with no spark
Hi everyone,
Thanks for reading my post and hopefully helping me fix my volvo.
i have a 1988 740 turbo that has no spark.
Personally I am not a car mechanic but I am very handy and deal with mechanical problems all of the time in a different field.
my car stopped running one day on the highway with no symptoms before it just shut down. When I try to turn it over it just cranks and cranks. When I got the car home i pulled off a spark plug wire and had no spark from it. Then I removed the center wire from the coil to the distributor and still no saprk..
I have looked through a couple forum threads and found out how to test the coils resistance and the primary and secondary were both within specs from my manual.
Also while cranking the engine I had oscillating power, however I dont know what type of power readings I should have. \
Can someone please give me some more test ideas..
Old Aug 25, 2010 | 06:30 PM
TURBO 245's Avatar
There could be several things that cause a no spark issue.You need to check for cam rotation first.
Remove the oil filler cap,look down through the hole at the cam,have someone crank the engine over.Is the cam turning?
Dan
volvoguy23
Apr 8, 2012 05:26 AM
88turbo
Jan 19, 2012 09:30 PM
catpressedjeenz
Aug 20, 2010 09:19 AM
Ratphink120
Aug 26, 2007 12:34 PM
Ratphink120
Aug 16, 2007 10:03 AM
