Front passenger side window glass broken
Old Sep 1, 2010 | 06:36 PM
mark458's Avatar
Default Front passenger side window glass broken
OK I neded to replace my window. Went to a salvage yard and bought the window ($40) took the panel off the replace the glass but found the the door is welded shut... WTF! Am I missing something here?
Old Sep 1, 2010 | 06:47 PM
mark458's Avatar
This is what VADIS says
Remove:
-the door panel. See Panel, front side door, replacing (-2003) or Panel front side door, replacing (2004-)
-the sound proofing and bracket. See Drip guard .
-the ball joint from the clip in the window mounting.
Insert a screwdriver. Pry until the clip and ball joint snap free.
Note! Drill out one of the rivets then move the drip guard to one side.
That doesnt mean **** to me. and the picture they give you is SO vague. AND volvo put in RIVETS on a replacable part! MORONS!
Old Sep 1, 2010 | 07:55 PM
beefheart's Avatar
rivets are used on many areas of a car that eventually will need replacement, you drill out the rivets, replace the part and install new rivets, these are things that happen to be facts of life in auto repair, sorry that you are having a bad time with this, best regards, beefheart.
Old Sep 1, 2010 | 08:19 PM
If you are only replacing the glass there is access holes to get to the clips on the wheels.
Old Sep 1, 2010 | 09:56 PM
mark458's Avatar
I have to replace the glass and the regulator
And no Ive NEVER owned a car with rivets on a serviceable part. Ive owned over 20 cars and never had that.. Although this is my first euopean car.
rfrew
Oct 25, 2019 08:24 AM
antheo
Sep 29, 2011 09:26 PM
timer00
May 4, 2011 04:28 PM
schrysco
Feb 27, 2009 11:33 AM
schrysco
Feb 19, 2009 07:11 PM
