Replace Rear Passenger Window glass?
Old Nov 20, 2014 | 05:17 PM
rfrew's Avatar
Default Replace Rear Passenger Window glass?
Had my right Rear passenger window glass smashed in after a visit to SF in my 2010 S40. I got a new piece of glass from a junk yard but I can't figure out how to replace it.
Any help or guidance to a forum thread would be appreciated! Can't find crap online about replacing the window glass.
Old Nov 21, 2014 | 09:27 AM
mf70's Avatar
Download the VMware VIDA image and the VMware player (both free).
Vida says (it has illustrations):
Removing the rear door window
Remove:
the side panel in the rear seat as described in
the inner and outer weatherstrip
the 7 screws and 2 nuts of the plate bracket
the plate bracket
Note! Use butyl or the like as it is easy to drop the nuts and washers.
Remove the 3 nuts and 3 washers.
Angle the bottom of the window toward the vehicle interior and remove it.
Installation
Installing the rear door window
Note! For tightening torques, see: Tightening torque .
Note! The regulator mechanism should be completely raised.
Note! Two people are required for this task.
Guide in the window.
Install:
the 3 washers
the 3 M6 nuts. Adjust as described in Side window rear, adjusting
the 6 M6 and 1 M8 screws and the 2 nuts of the plate bracket
the plate bracket
the side panel in the rear seat as described in .
Old Jan 2, 2015 | 05:09 PM
rfrew's Avatar
I don't quite know what you are referring to. Kind of new here and I don't know what the VMware VIDA is? Is there a link? I have tried to follow the written directions but it still looks impossible.
Remove:
the plate bracket
Installation
Install:
the 3 washers
the plate bracket
Old Jan 3, 2015 | 06:32 AM
Hudini's Avatar
VIDA is Volvo Information and Diagnostics for Aftersales software. VMWare is a way to run VIDA in a virtual machine. Basically, VIDA is commercial software for dealers. It has been hacked to allow regular folks to use it but you need specific Windows requirements. Some very smart computer person has found a way for anyone to run VIDA inside a virtual machine, no matter your native Windows version.
Old Oct 25, 2019 | 08:24 AM
Graham Truman's Avatar
Did you ever get this sorted or find the guide?
lanerellis
May 2, 2013 07:20 PM
timer00
May 4, 2011 04:28 PM
mark458
Sep 1, 2010 09:56 PM
schrysco
Feb 27, 2009 11:33 AM
schrysco
Feb 19, 2009 07:11 PM
