Fuel Pressure Regulator 240 -- Will 88 work on 89?
Old Sep 2, 2010 | 09:30 AM
AnEskimo's Avatar
Default Fuel Pressure Regulator 240 -- Will 88 work on 89?
My girlfriends 89 240 wagon is having fuel issues, and I think I've narrowed it down to the fuel pressure regulator. I have an 88, and the local junk yard has an 88, and the regulator looks exactly the same, but everwhere I look online they seem to sell the 88 regulator, and the 89-93 regulator. What is the difference? Will an 88 regulator work on an 89?
Old Sep 2, 2010 | 10:41 AM
swiftjustice44's Avatar
The reason is the 240 went to LH2.4 Jetronic fuel injection in 89. The fpr's have different part numbers...0280160292 for 88, 0280160294 for 89+. The good news is, I'm bot sure the pressure is different...at most probably only .5 bar different. Her LH2.4 will compensate for any difference in pressure. What makes you think the issue is the fpr?
Old Sep 3, 2010 | 07:26 AM
AnEskimo's Avatar
Well when starting the car, you would have to turn it over 3 or 4 times before it would actually start, and then it would idle really rough, until finally dying altogether after about 10 seconds. I went ahead and pulled that FPR off at the junk yard for $20 and it fixed the problem! The junk yard car had a cool look speaker fade **** in between the rear defrost and hazards so I had to grab that of course too :P
Old Sep 3, 2010 | 10:22 AM
Nice score on the fade ****...those are kid of scarce these days. If the symptoms return, it may very well be the fuel check valve that is between the inline pump and fuel filter. That valve is what keeps the line pressurized and lowers starting time. It isn't essential unless you're in sub-zero temps...but nice to have the car right. Glad the fpr is working. With LH2.4 and a turbo motor in my 89, I've used 2.5, 3.0, 3.5 and 4.0 bar fpr's depending on the size of the injectors. LH2.4 will learn the changes in a day or so. Happy motoring!!
Old Sep 5, 2010 | 03:45 AM
volvoguy2323's Avatar
Banned
Yes it will work just fine as long as the fittings are the same stick her on...but really I would not recommend a used fuel pressure regulator..they are so cheap and they so often go bad it's best just to throw a new one on...good luck and hope this helps!!
MntnDewMan
Apr 3, 2024 04:05 PM
GrantRobertson
Jun 1, 2013 04:04 PM
hvolvo
Jul 15, 2012 02:17 PM
slsnumber1
Mar 15, 2011 02:55 PM
cdunning
Dec 28, 2005 01:27 AM
