display "dISC"
Old Feb 13, 2006 | 07:23 PM
tom1568's Avatar
Default display "dISC"
does anyone know what this means, it shows up on the dahs panel instr. it only happens intermitly and if i change the selector for the mile per hour or temp. it goes away, some times its up for a while or just a second or two! also is there a way to reset the service light, i had all my service work done and light is still on, any user way of turn it off?
thanks
tom
Old Feb 13, 2006 | 09:26 PM
Default RE: display "dISC"
The disc means the switch is bad. I think it is supposed to be programmed to mean disconnected.
The service light if you had the Dealer do it bring it back and have them reset it.
You need a special tool to do it.
Old Sep 15, 2006 | 05:58 PM
tysonthediva's Avatar
I to am having this problem.. I was told it probably has to do with the temperature sensor.. It happens mostly when it gets hot..
AlanT
May 22, 2011 01:43 PM
Steamroll9
Feb 24, 2008 04:58 PM
Volgrrr
Sep 15, 2006 08:40 PM
doug_999
Feb 6, 2006 01:08 AM
nilandr
Aug 7, 2005 12:04 PM
