Exhaust Fix 89 240DL
Old Sep 4, 2010 | 11:33 PM
palerider's Avatar
Default Exhaust Fix 89 240DL
Hello All,
I have a 89 240 and the exhaust pipe below the manifold where the two pipes turns into one gave way. The weld broke and I was driving for a week with a busted weld. It sounded like a Cessna airplane. I found a pipe for it at Advance Auto for $115.00 and it fit like a glove, only problem was it had a hole for the 02 sensor and the catalytic converter already had one. That was no big fix. After driving that day my check engine light came on, I think it could be the 02 sensor not getting exhaust. My question is where do I reset/clear the computer. i see the place where you test it but don't see the reset.
thanks
Old Sep 5, 2010 | 02:52 AM
volvoguy2323's Avatar
Banned
Originally Posted by palerider
Hello All,
thanks
Driver side fire wall little black box. remove cover and take prong out and insert into hole #2. Hold button down for 2 seconds and release. You will see a seriers of flashes example..1 1 1 which means system is good. O2 sensor code is 2 3 2. Make sure you repeat until all codes have trepeated themselves or it will not let you clear. for example if you get code 2 3 2 and then you hold button down again and release and you get same code 2 3 2 then you can reset..to reset hold button down for 10 seconds and then release.. red light will come on. hold button again for 8 seconds and release...computer should be cleared. also put prong in hole # 6 and repeat process. Obviously you will have the key on the on position or car running..hope this helps and good luck!!
Old Sep 5, 2010 | 05:12 PM
palerider's Avatar
Thanks for your help, it was the 02 sensor. I cleared it out. Thanks to ya again.
Old Sep 5, 2010 | 05:14 PM
palerider's Avatar
TThanks it worked
Old Sep 5, 2010 | 10:52 PM
Banned
No problem that's why I'm here
drenman
Nov 29, 2016 07:35 AM
theotherpilot
Jul 10, 2009 12:28 AM
Fluxmotoring
Nov 18, 2008 02:53 PM
240nc
Apr 15, 2008 08:45 PM
Volvorator
Mar 15, 2007 10:37 AM
