Help with these codes
Old Mar 30, 2006 | 12:50 AM
Riculus's Avatar
Default Help with these codes
My check engine light came on and I got these codes.
P0730 - incorrect gear ratio
P0120 - Throttle position sensor
Can someone tell me what is the deal with the " incorrect gear ratio" I guess the throttle sensor needs to be changed.
Thanks for ur help
Riculus
Old Mar 31, 2006 | 09:42 PM
Default RE: Help with these codes
The P0730 - incorrect gear ratio May have come from the throttle position sensor code.
Clear all of them and see what ones come back.
Old Apr 3, 2006 | 12:22 AM
Riculus's Avatar
I cleared the codes and only the
came back. I guess the sensor needs to be replaced.
Thanks for the info tech.
Riculus
95 850 GLT non-turbo
Old Jun 8, 2009 | 09:45 PM
afa7's Avatar
Same P0120 error with my 1998 S70. Tried putting in a new TPS and a new used TCU. After a few hundred miles code comes back again. Did you ever find a solution?
Old Nov 19, 2009 | 06:35 PM
kurai's Avatar
I have the same p0730 code along with p0331 and p0400
we cleared them out and they all came back
Old Nov 20, 2009 | 04:28 AM
Ok, I see you posted this problem in another post. Work on it there and please post back with your fixes.
healthnt
Jul 6, 2010 12:07 PM
Armenian
Mar 4, 2009 07:31 PM
atikovi
Aug 17, 2006 10:20 PM
fishbulb95
Apr 5, 2006 12:48 AM
ludeless
Dec 9, 2005 08:51 PM
