What do these OBD2 codes mean for '98 C70 that won't shift?
Old Aug 17, 2006 | 06:34 PM
atikovi's Avatar
Default What do these OBD2 codes mean for '98 C70 that won't shift?
The upshift arrow is blinking and the check engine light is on and I got two codes. A P1618 which the code scanner doesn't recognise but VADIS says it's "DTC in another control module," and a P0758 which the scanner calls "shift solenoid B circuit electrical" problem. Where do I start?
Old Aug 17, 2006 | 06:42 PM
cbevis's Avatar
Default RE: What do these OBD2 codes mean for '98 C70 that won't shift?
probably with replacing the overdrive solenoid?
Old Aug 17, 2006 | 07:20 PM
billofdurham's Avatar
For what it's worth P1618 is "Signal through the connection between ECM (B26) and TCM (B15) too low. Flash EPROM Reprogram Error."
If you know what it means let everybody know, please.
Old Aug 17, 2006 | 09:32 PM
Did you clear them and they can right back?
Old Aug 17, 2006 | 10:20 PM
atikovi's Avatar
Yes.
healthnt
Jul 6, 2010 12:07 PM
willko1
Oct 13, 2008 08:08 AM
skyflier66
Mar 4, 2008 05:42 PM
805c70
Intake, Headers and Exhaust
Aug 30, 2007 02:07 PM
my_d3c3mb3r
Mar 24, 2006 09:30 PM
