Sights N Sounds Post all of your video and sound clips here.
Knock sound from transmission 1991 240
Old 01-03-2017, 07:46 PM
Andrew Cuffman's Avatar
Default Knock sound from transmission 1991 240
I have a 1991 Volvo 240 4cyl with 218xxx+ miles on it. A couple months ago it started making a knocking sound that I thought was the driveshaft hitting. I stopped driving it and figured it may have been the u-joints because I had recently replaced the motor and transmission mounts. They were bad, so I thought that could have damaged the u-joints. I replaced all 3 and the sound went away for a couple months until I backed up an incline and the exact same noise started again. I drove it for awhile and it went away. Then it came back again when I backed up a small incline, which seems to cause it initially whenever I do this. The noise only happens when switching between driving and coasting at low speeds, like below 25mph. When driving any faster than this, the noise is nonexistent. No signs of anything obvious hitting underneath.
rdklxprs
07-21-2015 09:46 AM
andrewwhite149
04-22-2012 01:33 PM
ruggles
03-03-2010 04:19 PM
v70 2.4t
01-27-2009 10:24 AM
lizard
09-01-2005 08:48 PM
Quick Reply: Knock sound from transmission 1991 240
