Automatic trans shift indicater
RE: Automatic trans shift indicater
There should be a couple of screws holding the plastic around the shifter assembly. They should be in the front of the panel. Then you slightly lift up then slide towards the back of the car to slide it off the tab.
Then you get into the rest of the parts.
ded137t5r
06-10-2012 07:40 PM
daviddward1
10-30-2011 11:22 PM
