Automatic trans shift indicater
Old Dec 12, 2008 | 03:58 PM
emm01's Avatar
Default Automatic trans shift indicater
how do you replace the shift indicator, is their a easy way to remove the top of the shifter and than replace the plastic, thanks in advance
PS 1988 240
Old Dec 12, 2008 | 04:41 PM
Default RE: Automatic trans shift indicater
There should be a couple of screws holding the plastic around the shifter assembly. They should be in the front of the panel. Then you slightly lift up then slide towards the back of the car to slide it off the tab.
Then you get into the rest of the parts.
mathieu_p
Jan 19, 2013 02:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Pyrate
Jun 15, 2009 02:17 PM
Bummer
May 27, 2005 10:24 PM
