Electricity problems. SRS light on.
Old 11-12-2011, 04:23 PM
Wicksvolvo's Avatar
Default Electricity problems. SRS light on.
When I turned my volvo on, the service light would be on, and go away after about 30 seconds. About 3 or 4 days ago my check engine light came on and my srs light is on most of the time. when my srs light is on I get no power to my airconditioning, my radio, certain lights in my car, but the power windows work, and my head lights also work, any help on what it could be?
Old 11-13-2011, 01:13 AM
Titan Joe's Avatar
Check fuses on those circuits.
Check this for SRS codes and clearing:
https://volvoforums.com/forum/volvo-...89-740t-52140/
And also, what year and type of Volvo is this?
Old 11-14-2011, 07:26 AM
lev's Avatar
lev
lev is offline
First, make sure that your battery is OK, and that your charging system is doing its job--putting out about 13.5 volts at idle.
Old 11-14-2011, 09:06 AM
Wicksvolvo's Avatar
Default 90 volvo
It's a 1990 240 dl.
Old 11-14-2011, 09:09 AM
Wicksvolvo's Avatar
Default Turning car off then back on
When I turn the car on and the SRS light is on, I can turn the ignition off and on and then the SRS light will go off and I will have all accessories working (radio, defroster etc)...however, accessories can sometimes fail and the SRS light come on while driving.
Any ideas?
Old 11-14-2011, 11:51 AM
lev's Avatar
lev
lev is offline
You may have a bad ignition switch and/or a bad Circuit Board on the instrument pod.
Old 11-14-2011, 01:08 PM
Wicksvolvo's Avatar
Default Diagnosing/TS
Any suggestions as to how to troubleshoot without replacing both switch/circuit board?
Old 11-14-2011, 10:29 PM
Burn Stains's Avatar
Remove the negative battery terminal and reset everything?
That could be a start.
Then maybe check the SRS codes.
You could just have some bad ground connections.
huqqis
2001-2013 model year V70
03-18-2013 12:27 PM
kzorn1989
11-09-2010 11:36 AM
afa7
04-20-2010 11:16 PM
Sparky4688
09-26-2009 06:22 AM
VolvoDriver
09-06-2006 08:41 PM
Quick Reply: Electricity problems. SRS light on.
