Tail light Failure 240DL Sedan?
Old 10-29-2004, 08:16 PM
FCHicks's Avatar
Default Tail light Failure 240DL Sedan?
Hi all:
My brake light RH side rear on my 240 DL will not come on! I have repaced the bulb and jiggled it a bit, and still wont light up. These tail lights are fairly new and it was working for a while?
Any ideas?
CH
Old 10-29-2004, 09:20 PM
Default RE: Tail light Failure 240DL Sedan?
Check your pulg where it plugs into the taillight sometimes they get dirty or rusty.Also remove the taillight and clean the connections on the socket and the circuit board.Try this and let me know how you make out.
Old 10-29-2004, 11:26 PM
I have an 82 240 wagon, sometimes I have that same problem, but what funny is its intermittent, most of the time it works... sometimes it doesn’t... just like the passenger power window... and the drivers window... and...
Old 10-30-2004, 12:30 AM
Also for everyone reading this about once every 6 months remove all the fuses from the fuse box.Clean the contacts on both sides or they build up corrosion and intermittently lose connection causing electrical problems.And on the tail lights after cleaning contacts carefully bent the tabs on the socket to make it fit better and make a good connection.
Old 12-11-2004, 11:35 PM
Just replaced the circuit board on the RH tail light hopeing that the brake light would work. No luck? Both brake lights work without headlights on but RH side (Brake light) doesn't light up with the headlights on and brake pedal is depressed. I noticed the safety light in the rear window had a blown bulb too. Could the circuit to the RH brake light be affected by that safety warning light? ?Puzzeled.
Old 12-12-2004, 11:33 AM
I would make sure you put all your ground wires back on when you reinstalled the taillight.Is the connector very clean.The only other thing I would be able to guess after that would be your bulb failure sensor.I don't think the 3rd brake light would effect the r/s brake light.You could also check the wiring at the plug with a test light and see if the same thing happens with the taillight unplugged.
commoncold
06-25-2014 10:38 PM
nitrosport
03-29-2012 02:33 AM
ZephLeggett
03-28-2010 10:43 AM
Rev0verDrive
03-20-2010 11:31 AM
jetfire
07-02-2009 12:41 PM
Quick Reply: Tail light Failure 240DL Sedan?
