Trans mount issue
Old 07-13-2010, 03:00 PM
billdrah's Avatar
Default Trans mount issue
I have a 1989 740 turbo sedan, with a manual transmission and overdrive. The car has a bad shake when starting out in first which is worse if a heavy load is placed on the car. I have checked the drive shaft, flex plate and center carrier bearing all appear to be in good shape. I see the trans sits low so want to replace the trans mount as next possible problem spot.
Here is my dilemma, ever parts house including the dealer tells me I should have a round mount, but the car has a square mount like the automatics have. The cross brace fits this square mount and the trans has a stud which appears to corresponds with that type of mount. Any Idea why this would be?
Attached Thumbnails Trans mount issue-sq-mount.jpg   Trans mount issue-rnd-mount.jpg
Old 07-13-2010, 05:42 PM
volvoguy2323's Avatar
Banned
I have seen both too but typical set up on a 740 is a square mount for manual and square for automatic...there are 2 different types of square mounts one is short and one is long...doesn't matter as long as it fits correctly(make sure you match yours up). But if you have a bad shake usually the motor mounts are bad...not just tranny mount...check motor mounts too.
ded137t5r
06-10-2012 07:40 PM
tuner4life
04-27-2012 06:41 PM
Eric's Hot Rod Shop
07-14-2011 08:26 AM
VTBricked
11-21-2009 07:50 AM
Typhoon
11-09-2009 08:49 PM
Quick Reply: Trans mount issue
