Gearshift Won't Shift Gears
Old 01-16-2012, 09:31 AM
allenzachary's Avatar
Default Gearshift Won't Shift Gears
1997 960 Wagon 217K
My daughter's (sidebar: "My daughter's..." is a common theme here. Seems we all like to wrap our little girls in a lot of safe Swedish metal) gearshift on her 97 960 suddenly will not shift between P,R,N,D etc. There is free movement on the gearshift itself, and it feels like something like linkage has disengaged.
Car drove fine until she tried to put in Park in our driveway (thankfully it waited until she got home). Even though she put it to the "P" the car engaged in reverse. She stepped on the brake, tried to put it in Park again, but when it failed, she shut the car off.
Is this some kind of linkage issue? Would it be at the console or underneath?
Over the weekend I had the car up on jack stands. I wonder if lifting it caused any problems.
Any help would be most appreciated.
az
Old 01-16-2012, 05:32 PM
Default Follow Up...
Posting in case anybody needs this later. Problem was indeed the linkage.
The bottom of the gear shift is connected to a 1M or so lever using a thick pin and a "c" connector that snaps into a groove in the pin and holds it in place. The other end of the lever connects to using a similar pin to another lever, which switches the transmission through PRNDL settings.
The C-connector came off at the transmission lever and left the long lever hanging uselessly.
The local NAPA parts folks didn't have the C-connector, so we improvised, using a threaded bolt in place of the pin and a pair of nuts tightened against each other in place of the C-connector. Worked like a champ for less than a dollar!
Old 01-19-2012, 01:38 PM
You was able to access that linkage from unde the car correct? From the passenger's side?
Old 01-19-2012, 05:18 PM
snowboss's Avatar
nice fix
not broken linkage ...but mine has the notorious ignition switch bug......start the car and you have to turn the key back just a touch.......if you don't turn it back the dash power, radio climate control don't work.......as well as you can't shift it out of park.......i about ripped the shifter out of the console the other day before i realized the radio wasn't on and i turned the key back and proceeded on my way like i knew what i was doing...lol
just another friendly Volvo bug reminder .........nice fix BTW
Old 01-19-2012, 09:56 PM
That ignition switch is about $59. It's easy to replace. I actually liked mine being bad. Looked at it as a security feature.
Old 01-20-2012, 07:12 AM
I accessed the linkage from the driver's side. Once I got under there, the problem was very obvious.
Good to know about the ignition switch. I'll keep my eyes open for it.
Thanks for the compliment. I was kind of proud of myself. Even my wife was impressed.
Old 01-20-2012, 05:38 PM
snowboss's Avatar
hey if you can turn a wrench and impress the wife at the same time.....you are in like flinn buddy....lol
rspi......i agree....my daughters battery died in her 850slt and she just jumped in the wagon without asking anyone, not knowing the wife had jury duty ....and viola she couldnt get it to move...................never thought of not fixing it, theft deterrent is a great idea
will the switch eventually not work though...or is the little turn back thing all that it does?
Old 01-20-2012, 07:07 PM
Man, I turned my back for years. Worked every time.
Your 850 is a GLT, not SLT, correct?
Old 01-21-2012, 08:12 AM
snowboss's Avatar
nice...i think ill leave it ..lol
ill double check for sure but it says SLT on the badge to the right of 850
Old 01-22-2012, 08:39 AM
snowboss's Avatar
RSPI....i stand corrected......took the dog out and looked at the 850, 850 on left side of trunk and GLT under the left tail light ....my bad sir
Old 01-30-2012, 02:44 PM
Follow up:
The pin that holds the linkage to the transmission is the exact same pin that holds the hood support to the hood. I recently changed the hood supports and had an extra clip in my tool box. The clip fits perfectly onto the the transmission pin.
So...
Do I leave the threaded bolt and nuts on there? Or should I go underneath and put the Volvo engineered pin/clip combo back in as it was designed?
Old 02-02-2012, 12:53 AM
swestleyg's Avatar
My 1996 850 is having the same type of issue. I've been having to use the shift lock override button more and more frequently; every other time I drive it or so. I think all my lights and radio, etc. still work when I turn the car on, so I'm wondering if the slight counter-clockwise turn solution will work for me? I'm just nervous because the release button seems kind of reluctant sometimes. I am very clueless, and needing to be thrifty, and would appreciate any and all advice! Unfortunately I just moved 400 miles away from my uncle who is my mechanic. I'm going to give him a call tomorrow but was hoping someone could throw me a bone on here, I guess! (A bone of helpful wisdom?) I think I'm also leaking coolant. I replaced the radiator three years ago when I bought the car. Hoping the two problems aren't related but I think I'm going to have to face the music this time.
Volvo-Finn
03-21-2011 11:47 AM
RGT
09-17-2009 05:16 AM
snuggletime
04-25-2008 08:46 PM
trajan
06-27-2006 01:51 AM
Quick Reply: Gearshift Won't Shift Gears
