When Replacing the Front Crank Seal ...
... on a 1990 760Turbo, what else should I get done? Timing belt I figure (car has 118K miles and I bought it used and TB looks Orig Equipment). Cam seal too? Belts too (except the new one just installed). Anything else? Should I have the PCV system looked at too?
Thank you wise ones.
Replaced 3 front seals (cam, crank and intermediate),TB and tensioner, oil cooler seals, turbo oil drain seal which were also leaking. Also worn transmission shaft bushig and leaking seal. $1100 USD. Done by a shop locally with good reputation. Done in 1 day. Sound about right?
What is book hours for all these pls?
ZaphodBblbrux
07-02-2012 09:54 PM
