dash lighting up!
Old Oct 4, 2009 | 12:24 AM
thegreatkhan90's Avatar
Question dash lighting up!
Hey guys! so i've recently encountered a problem with my 850 and its a consistent one. every time i press down on the accelerator pedal, my radiator light pops up followed by the windshield wiper fluid light. what's goin on?
When i release the pedal, they'll go away and won't come back until i take off from idle again.
maybe this is a noob problem, but i've never dealt with this kinda thing before so idk.
help?
Old Oct 4, 2009 | 12:41 AM
jnduke's Avatar
check your fluid levels- they are most likely low. When you gun it (good for you!) the fluid sloshes around and gives you that low reading. Volvo is very specific about using only their brand of antifreeze- it's about $20/gal. Usually if you are pretty polite that parts guys will give you shop price if you'll be buying parts from them regularly.
hope that helps.
Old Oct 4, 2009 | 09:27 AM
JPN's Avatar
JPN
Volvo original coolant is not much different from high-quality aftermarket coolant (I've been using Prestone). As long as you use aluminium-safe (most of them are safe for aluminium these days) ethylene glycol-based coolant, your cooling system should be fine. Keep in mind to replace it at every 30,000 miles/3-4 years. Coolant is one of the most neglected items in modern cars.
+1.
JPN
thanks! i checked my fluid levels not too long ago when the problem first occured.
I'll check again today though.
Old Oct 4, 2009 | 11:08 AM
850tony's Avatar
9 times out of 10 its just low fluid. i cant say that i have ever seen an issue with the sensors systems that magicly makes lights pop on.
let us know how it turns out.
Old Oct 4, 2009 | 01:41 PM
LOL that's exactly what was going through my head.
will do.
Old Oct 4, 2009 | 08:08 PM
woodsytf's Avatar
Talking wiseguy...
lay off the accelerator, you're gonna burn out the lights!
just kidding...
Old Oct 4, 2009 | 09:34 PM
850tony's Avatar
^^^^ HAHAHAHAHAHA thats a good one.....
Old Oct 5, 2009 | 08:38 AM
just kidding...
haha! Im sorry! i try to but than it feels like im going way to slow.
plus i don't press down on the pedal THAT hard. lol
trs80
Jun 25, 2011 02:05 PM
bluefox
Nov 19, 2010 02:08 PM
tr_car_nut
Jan 19, 2008 09:37 AM
TonyS40
Nov 24, 2006 05:07 AM
