dash board lighting
Old Nov 23, 2006 | 07:48 AM
TonyS40's Avatar
Default dash board lighting
On going dash lights problem - can anyone advise if it is possible to replace the ash tray/cigarette lighter bulb at home or is this a dealer fix?
Old Nov 23, 2006 | 08:11 AM
vasilisuk's Avatar
Default RE: dash board lighting
Today as soon as I get home from work, I will try to replace it and I'll let you know :-)
Old Nov 24, 2006 | 02:52 AM
vasilisuk's Avatar
On my S40 (2000 model) it is easy to change; Remove the ashtray and loosen the two screws that hold it's frame in place. The screws are at the top of the frame and can be seen bellow the ashtray flap. Then remove the plastic cover between the ashtray and the gear lever. This cover accomodates the switches for heated seats and DSA, and can be removed using a small screwdriver to loosen the latches that keep it in place (three latches, one on top and two on the sides. first loosen the side latches). When you do that there is a chance that the soft cover of the gear lever is removed as well, but you can easily put it in place after replacing the lamp just by pushing it down. Now you can pul out the ahstray-lighter assembly with a twisting movement (from the bottom to the top). Remove the cable connectors of the upholstery light and the lighter. At this stage you should have the ahstray-lighter assembly in your hands and the only thing left is to replace the lamp.
Hope it helps!
Old Nov 24, 2006 | 05:07 AM
TonyS40's Avatar
Thank you so much for that info - will address today.
A further question, I was under the impression there was back lighting on the light switch panel which includes dimmer/fog lamp switches, can you confirm yes or no please - thought the back lighting was in fact dimmer controlled
tech
Oct 10, 2017 09:43 AM
MannyGoncalves
Mar 21, 2008 06:51 PM
detrock
Dec 23, 2007 05:30 AM
89T740
Mar 29, 2007 05:19 PM
jpirish
Dec 17, 2006 05:27 PM
