Help! I'm replacing alternator, forgot pulley bolt locations...
Old 09-01-2012, 01:55 PM
Vmax's Avatar
Default Help! I'm replacing alternator, forgot pulley bolt locations...
So i've pulled the old alternator, installed the new one, but I can't seem to remember where the assorted brackets go.
From what I understand this is the idler pulley:
This is the serpentine belt tensioner:
Now this triangular piece is what's tripping me up:
Pulley and bracket placed but not bolted to the car(w/o triangular piece):
Power Steering pump bracket(I have an idea where that goes:
I've searched and read writeups but am getting frustrated. Any and all help will be needed and appreciated.
Old 09-01-2012, 03:25 PM
I'll go look.
Old 09-01-2012, 06:17 PM
Not sure how much help this will be but here are a few pics.
Couldn't really see much.
Old 09-01-2012, 06:37 PM
Vmax's Avatar
Thank you sir! I got a tip from a member on volvospeed.
Car is back together now.
Old 09-01-2012, 07:53 PM
ibified's Avatar
Awesome! How much stuff did you have to remove to get to it? Looks like a pain...
Old 09-02-2012, 12:40 AM
Vmax's Avatar
About 16 bolts not including undoing the fuel line above the fuel rail, removing the thermostat housing, taking off theupper radiator hose, AND chopping up the ecu box a little..
Took me longer than expected AND my body is now beat...reminds me of my days as a mechanic.
The worst part of this is the power steering pump bolts, two out of three are dirty ****** that don't want to find the hole in the bracket.
Old 09-02-2012, 06:14 PM
Sorry I wasn't faster but it will help the next guy who ends up here.
Alternator Replacement - FWD/AWD 1998 and Prior - Volvospeed Forums
One guys comment on the above procedure:
Theres a big shortcut on how to do this in the Chilton book on page 2-11 in the 1990-1998 repair manual check it out if you have one. You have a good right up but you did not have to do alot of that stuff.
The power steering pump comes out attached to the tensioner bracket.
audihenry
10-20-2012 05:51 PM
migbro
06-14-2012 07:41 AM
guest01
11-05-2011 10:11 PM
pglickenhaus
07-03-2006 12:45 AM
s40guy
05-31-2005 10:12 PM
Quick Reply: Help! I'm replacing alternator, forgot pulley bolt locations...
