Low Engine Oil Indicator Light
Old 09-27-2005, 11:06 AM
migkam's Avatar
Default Low Engine Oil Indicator Light
After driving for about 1/2 hr and made a quick stop, the Low engine oil indicator light turned on, on my 93 850GLT after re-starting the car. Stopped at a gas station to check the oil and it was full. Re-started the engine again and the light was gone. This is the 3rd time it happened in the last 3 weeks. As always, the oil is full. Any ideas why this is happening? Is there a sensor going bad? Where is this sensor located?
Old 09-27-2005, 09:11 PM
Default RE: Low Engine Oil Indicator Light
The sensor is located in the front of the engine in the middle.It has one wire going to it.
It might be the sensor or you have low oil pressure.
You migth want to check the oil pressure as well.
Old 09-27-2005, 10:35 PM
migkam's Avatar
Thanks for the info. How do you check for the oil pressure. The oil pressure light does not light up though.
Old 09-28-2005, 01:15 AM
You will need to find a oil pressure guage that will hook up to your car.
br549
09-21-2013 05:47 AM
the_brain3000
10-28-2011 05:53 AM
orcutd
09-27-2008 08:13 PM
oldbug
11-26-2007 08:24 PM
elderzap
11-07-2007 04:58 PM
Quick Reply: Low Engine Oil Indicator Light
