What is the back spacing, offset and bolt pattern for a Volvo rim?
Old 01-31-2008, 08:20 AM
Cobra Jet's Avatar
Default What is the back spacing, offset and bolt pattern for a Volvo rim?
Do any of you know the back spacing, offset and/or bolt pattern for a factory Volvo rim?
Old 01-31-2008, 03:38 PM
RedTurbo850's Avatar
Default RE: What is the back spacing, offset and bolt pattern for a Volvo rim?
5x108 is the bolt pattern. Not sure about the others.
Old 01-31-2008, 03:53 PM
S70driver's Avatar
Have you used the Volvo Forums Resources Thread at all? Do you know it even exists on this forum? If not you need to check it out.
https://volvoforums.com/m_38606/tm.htm
Within there you shall find a BOLBED section titled VOLVO RIMS. Check that out. It should help you.
Also your not giving us much info. What Volvo rim? Any Volvo rim? Because some Volvo's have different bolt patterns and certianly some have different offsets.
But an 850 uses a 5x108mm bolt pattern.
ltruong81
03-14-2015 02:10 PM
pfc
08-10-2009 02:47 PM
Platinum52
02-07-2009 10:10 AM
Scruggs
08-23-2007 03:31 PM
m4gician
01-03-2007 02:11 PM
Quick Reply: What is the back spacing, offset and bolt pattern for a Volvo rim?
