Radio issues with a 76' 850
Old 03-06-2016, 12:01 PM
Luke Woessner's Avatar
Post Radio issues with a 96' 850
My radio has recently failed and I'm trying to diagnose the issue. The stereo will still turn on and turning up the volume lets me hear some static. No signal from FM 1 or 2 but weak signal from AM. Antenna still extends and retracts properly. Any recommendations?
Old 03-06-2016, 02:55 PM
thread moved to 850 forum.
Old 03-06-2016, 10:40 PM
Psaboic's Avatar
Check the antenna connection at the back of the radio. To remove the radio, press in on the two small vertical slits on the front of the radio. Two handles will pop out and allow you to pull out the radio.
Old 03-07-2016, 06:01 AM
Is the antenna connection the smaller cable group or the larger one?
Old 03-07-2016, 09:37 AM
Psaboic's Avatar
It should be one cable about the thickness of a pencil (looks almost like a cable TV cable).
98_S70_T5_Driver
04-28-2011 12:50 PM
ROBLU540
04-19-2008 09:50 PM
cbgav
09-10-2007 05:25 PM
Quick Reply: Radio issues with a 76' 850
