what does the fuel pump relay do???
Old 01-20-2009, 05:34 PM
chef's Avatar
Default what does the fuel pump relay do???
Hi guys, well i just wanted to know what exactly the fuel pump relay do??? i figure the fuel pump sends the gas to the engine, but what is the job of the relay? what would be the symptoms on the relay stating to work improperly? thanks
fabs
Old 01-20-2009, 05:42 PM
Default RE: what does the fuel pump relay do???
Well if the relay was bad the fuel pump would not get power or would lose power from time to time.
It works in line to help drop Amps the fuel pump is pulling.
Old 01-20-2009, 05:55 PM
chef's Avatar
Hey Tech...cool...if not working 100% can it cause a slight drop in performance as well? (cyl. not getting enough gas//running lean)??
thanks
fabs
Old 01-20-2009, 06:15 PM
Not really it usually either works or doesn't.
Old 02-12-2009, 11:08 AM
gabyman97596's Avatar
Exclamation location of the fuel pump relay on a 1992 240
where is the location opf th efuel pump relay of the a volvo 240 1992
sleech
01-25-2020 05:07 PM
spidersilva
08-17-2011 07:23 PM
montysano
09-09-2008 11:52 AM
crazypixie
01-22-2005 01:01 AM
Quick Reply: what does the fuel pump relay do???
