Sc-901 radio CD player
Old Apr 29, 2013 | 10:45 AM
Rrvarnum's Avatar
Default Sc-901 radio CD player
Hello. I have an sc-901 system in my c70 which is great but the CD player does not work. When trying to use it just goes in and out when the 3 disk changer is pressed into the slot. Anyone have any idea for repair shop in California? I'm in the Long Beach area.
Old Apr 30, 2013 | 03:18 AM
MSGTUSMC's Avatar
Smile Sc-901
Had same problem with mine. 98 C70 Coupe. I purchased a replacement SC-901 from e-bay. While waiting for delivery I stopped by the local Volvo dealer to inquire about repair. Dealer informed me they did not repair these units. Received e-bay unit, removed original unit, installed replacement worked perfect. Just to test, removed replacement unit, re-installed original unit, it worked fine! Appears like removing & replacing it reset something. Works perfect today, 1 year later. Just my experience! These units are hard to find with the 3 CD changer. Now I have a spare!
Old Apr 30, 2013 | 04:41 AM
I have a spare stereo as well. If you find one grab it.
Old May 9, 2013 | 02:20 PM
cadaron's Avatar
As long as you have the radio code!! try this, as I had a similar problem on the SC-901;
turn the radio on; pull out the fuse which will shut the radio down; there are 3 fuses I think, just pull one at a time until it shuts down; turn the radio off; replace the fuse; turn the radio on; radio code will be requested; enter the code; try inserting the cd cartridge.
This has basically reset the radio, as I said it worked when my cartridge failed to load.
Hope this helps
Old May 20, 2013 | 09:16 PM
ehinson's Avatar
I fixed a friends V70 that did the same thing, his issue was it had two cd's stuck inside the unit, may or may not be your issue but just in case take a small flashlight and look in the unit.
I pulled them out with hemostats.
Old May 28, 2013 | 12:39 AM
Edwardwhite's Avatar
thanks for help as this problem is very frequently popping up in my car .. i hope this not going to happen again as your suggestions may make a difference...
davesodapop
Aug 13, 2014 10:51 AM
bjblackmore
Jun 25, 2012 10:44 PM
claybo
Dec 29, 2008 06:08 PM
argon
Sep 2, 2008 10:22 AM
rmmagow
Jun 22, 2006 02:25 PM
