Volvo C70 timing belt and 90k maint question
Old 11-08-2007, 10:25 AM
teaberry's Avatar
Default Volvo C70 timing belt and 90k maint question
Hi all,I bought my C70 used at 88k and I notice the last dealer service was done around 83k miles. There was no details but a stamp from a Volvo dealership in San Antonio with exact miles was in the service booklet. Before I call them up to see what was done to it, I was wondering if anyone know when the timing belt was supposed to be changed on C70 2.3L? I know Audi A4s are typically at 70k miles. Also, is there a way for quick visual inspection to see if the timing belt is somewhat new or not?
I am going to take the car in at 90k service to dealership soon. The Volvo booklet was a little confusing but besides oil/filter change, what is needed at 90k and how much do you guys normally pay at dealership? Is going to Sythetic at 90k recommended? Brand? TIA
Old 11-08-2007, 04:00 PM
PANTYEATR's Avatar
Default RE: Volvo C70 timing belt and 90k maint question
i just talked to someone at the volvo store here and they informed me that the timing belt job is the biggest PITA! you have DOHC and variable valve timing to deal with and the pulleies need to be changes out as well. and that all requires special tools to do it right.
Old 11-08-2007, 09:31 PM
Yup, its a pain in the all, but I had mine snap on my Talon a few years back, and its sure is money well spent as preventative maintaience. new motors are not cheap compared to a belt job.....
S.
Old 11-09-2007, 08:03 AM
reg's Avatar
reg
reg is offline
You do not change any pullys. Replace the belt and the accessory belt. IPD has the only "tool" you will need which is a device to lock the cams so they do not turn and change the timing while you change the belt. I believe IPD also has a video that goes along with their kit. The dealer is quite costly to the tune of $550.00 as contrasted to IPD's price of appx. $100.00.
You need to flush your brake fluid, trans fluid, and coolant. Do not neglect the fuel filter which needs periodic replacement.
r.
Old 11-09-2007, 05:52 PM
PANTYEATR's Avatar
i figured that, the guy i spoke to was trying to scare me out of doing the job myself i bet. all i need is to be armed with the knowledge that i can find in a manual or something and i'm good.
Old 11-09-2007, 07:03 PM
ORIGINAL: PANTYEATR
One day you will have to come to my house and we will knock it out in a couple of hours(LOL) Maybe even less!!
Old 11-09-2007, 07:06 PM
ORIGINAL: teaberry
The 90K is a major tune up.
The 1998 cars are 70K for the timing belt.
The 1999 care and newer Volvo says "105K" (Laughing on the floor I wouldn't trust the belt past 70k)
I am working on making a write up about timing belts.
I am trying to gather a bunch of belts with many milages from S70's S60's S80's and S40's then I will take pics and make an entire post about the belts and replacing them.
Old 11-09-2007, 10:02 PM
when changing timing belt on owners and warranty manual they recommend u to change timing belt tensioner if it is the mechanical type.
Old 11-10-2007, 06:52 AM
reg's Avatar
reg
reg is offline
TECH, is the time limit predicated on beer consumption?? I have always found that the consumption is directly proportional to the time it takes to complete the job.................
r.
Old 11-10-2007, 08:43 AM
ORIGINAL: reg
r.
I cannot comment on that because I don't drink.
Old 12-12-2007, 01:06 PM
You forgot to answer one of his questions ... is there a visual way (or other) to tell if its been done recently?
i also just bought this, at about 90k...
Old 10-19-2008, 09:17 AM
hmcvey's Avatar
Does the IPD tool work on 1999 and up Volvo C70 engine B5254T? When I called IPD they indicated it did not because of variable valve timing, but the support technician telling me this was not familiar with how to do change a timing belt.
Looking at alldatapro instructions seems to indicate no concern on the cams moving during the procedure.
Now i am a bit confused, when changing the timing belt some posts indicate this is a good idea to lock the cams and some seem to indicate that no tool is needed. Is the IPD tool cheap insurance or with a variable valve timing it does nothing at all?
Rgds
Henri
ORIGINAL: reg
Old 10-19-2008, 09:20 AM
No special tool is needed.
Just mark from the pulleys to the top of the motor before pulling the belt. Make sure the marks are lined up before installing the belt and you will be fine.
I have done hundreds of timing belts on these cars and never used a cam tool just for the timing belt change.
I have locked the cams from the back when doing cam seals but you need to do that to make sure the VVT pulley goes back on in the correct position.
But if you aren't removing the pulleys no worries.
Old 06-10-2014, 01:52 AM
Syd_c70's Avatar
Thanks tech for the info since I will be doing this on a 2002 C70 since it has 192K on the clock (the belt was replaced @ 102K in 2008)
Old 06-10-2014, 04:14 PM
MSGTUSMC's Avatar
Not true. Just the belt at 10 yrs or 90k miles. Tight room but buy the kit and change water pump same time. I got the kit from IPDUSA.
Scancino
05-14-2011 09:44 PM
robertorevolvo
05-04-2011 01:24 PM
hawaii50
06-11-2010 10:59 AM
nomore740
02-20-2005 01:04 AM
OBXwahoo
04-16-2004 01:11 AM
Quick Reply: Volvo C70 timing belt and 90k maint question
