I have bad gas
Old May 18, 2014 | 11:35 AM
volvoC70GA's Avatar
Default I have bad gas
I have a 2008 C70 with bad gas. what's the best way to drop bad gas from the gas tank?
I tried the siphon method, but I suspect an anti-theft screen is preventing that method. Is there a drain plug I can remove? I've never seen the tank before so steps to access the tank would be much appreciated. I'll probably need to replace the fuel filter as well. I've never seen the bottom of the car before so steps to access the tank would be much appreciated.
thanks
Old Jun 23, 2014 | 04:28 AM
v5024's Avatar
Banned
'Bad gas' what do you mean by that?
Old Jun 23, 2014 | 10:31 AM
damien360's Avatar
Like v5024 said, what do you mean by "bad gas"?
There is no drain plug or out of tank fuel filter. The only way to drain it is by dropping the tank or running the car with a fuel pressure gauge connected with the relief on.
dman777
Jan 23, 2008 12:08 AM
samadkins29
Aug 18, 2007 01:57 PM
jollygoodgold
Jul 16, 2007 12:06 PM
glt93
Jul 8, 2007 08:14 PM
ko_kidd
Nov 5, 2006 05:52 PM
