Replacing the Climate Control Module
Old 05-27-2006, 12:07 AM
kenvolvos40's Avatar
Default Replacing the Climate Control Module
The climate control module in my 2001 S40 is acting up. It works for awhile and then turns off. No lights, nothing functioning.The dealership wants to replace the module but is not convinced that this will solve the problem.
I can get a used module from a junk yard pretty cheap but I am not sure how to install it. Anybody know how difficult it would be to remove the existing module and replace it???
Thanks for any info
Ken
Old 05-27-2006, 12:35 AM
Default RE: Replacing the Climate Control Module
It is pretty easy but I believe it needs to be downloaded.
The Grey/Wood cover pulls off then the module is screwed to the dash.
Old 06-10-2006, 07:08 PM
What you need is a set of picks slide them behind the cover on the frotn and pop it off like tech said. Then there is 4 phillips head screws. IT should be plug and play on that year car no software download. Just be care full slideing the new one in and out not to scratch the AC vents or radio becuse there are some prongs hanging off the bottom of CCM
RoyCross
07-03-2012 02:21 PM
mcslexus
10-31-2011 08:59 PM
Greenmudshark
10-15-2010 10:37 PM
Rosew6211
01-24-2009 07:22 PM
thejobark
01-30-2007 01:30 PM
Quick Reply: Replacing the Climate Control Module
