Volvo s40 2001 cold start problem/ hard start up
Hi I am new here!
I have a big problem with my Volvo s40 2001 so when I start it and it's cold then need long time to start but when it's hot everything is fine! I recently replace new battery and also fuel pump. I clean injections fuel pressure regulators and throttle. Nobody can't find what's wrong with this and I am asking for some help if someone has the same problem!
did you replace the fuel pressure regulator - the part that sits on the end of the fuel rail? Long cranking when cold suggests either an issue with the idle air valve (works as a choke) or the fuel pressure regulator (pressure is slowly bleeding off when the engine is off leading to low pressure at start up) or a fuel pump issue (not enough pressure). I had long cranking on my '00 (like 30 or more seconds) at cold start and replaced the pressure regulator (Volvo PN 8658092) which cured my car.
Hi I am new here!
the FPR has a diaphram in it that can tear - not sure how your mechanic determined its working fine. Bad news is the FPR is expensive ($200+). good news is that you can install in about 15 minutes (two torx screws and you need a pick/flat blade to pop off the fuel line fitting. plyers help with the on/off of the vacuum line).
I start the car and then I turn it off after this I pull off th S and the regulator was leaking gas so I need to replace it?
DecalService
12-04-2019 10:52 PM
hardluck
03-03-2012 02:20 PM
