volvo v40 2003 1.9d clock not working
Old 04-26-2015, 06:17 AM
Juris Dzelzkalejs's Avatar
Default volvo v40 2003 1.9d clock not working
hi. My volvo v40 not working clock, but when engine start up clock works.
Old 04-26-2015, 08:36 PM
does the clock work when you turn the key to position 2 or only when the engine is running? Are you referring to the digital clock in the instrument cluster?
Old 04-27-2015, 12:57 PM
yes clock work when the key ir position 2.
Old 04-27-2015, 01:35 PM
is this the clock in the instrument cluster? Do you know if anybody did any work on the car - ie replaced the ignition switch/key? You can try reading up on the wiring at volvowiringdiagrams.com but if its the digital clock in the instrument cluster, I'd say either the problem is in the key/ignition switch, somebody altered the wiring or in the cluster itself. If you can get your hands on a replacement instrument cluster (say one from a yard with a return policy) it should be pretty direct to swap out for a test.. Are there any other odd behaviors going on ie other courtesy lights not working correctly?
Old 04-27-2015, 02:32 PM
yes clock is in the instument cluster and it is digital. This problem star when I take off battery, before clock goes.
And all lights works correctly.
Skyharbor12209
08-13-2015 07:22 PM
dcmd
09-21-2014 12:43 PM
Esmat
05-29-2014 01:18 AM
rspi
06-29-2012 12:12 PM
Quick Reply: volvo v40 2003 1.9d clock not working
