S60R Trans Dripping
Welcome to the forum Markemark
Moved your post to the S60 section where hopefully you will get some help.
You can try putting some clean cardboard under the car when you park for the night and then use that to better locate the area it's coming from.
Common areas would be the connections at the transmission and at the radiator for the trans cooler hoses.
ded137t5r
06-10-2012 07:40 PM
