Water dripping on pass side
Old Aug 2, 2006 | 02:44 PM
pawel's Avatar
Default Water dripping on pass side
I just noticed that there is a water dripping inside the passanger foot area. It only happens after the AC is off after being used. Does this mean that the heater core is going bad? Or is something clogged up and water can't pass thru to engine bay via the rubber outlet which is just above the frame on righ side? Please if anyone could advise on the issue, I would greatly appreciate it.
Old Aug 2, 2006 | 10:24 PM
Default RE: Water dripping on pass side
It is a 960 correct?
It might be clogged or the Drain hose has sprung a leak.
Old Aug 3, 2006 | 09:56 AM
pawel's Avatar
Hi Tech. Yes it is a 960. I took off the plastic panel and the leak is coming from a black "box" (heat exchanger??) which runs all the way to the firewall. At its end, it has the tubing that goes thru the firewall. Looking at the front of the box, there are two screws on each corner, and one of them is lose. someone overturned it and it doesn't grip anymore. So I will use the J P weld stuff to seal it. I will post pics when I'm done.
Old Aug 3, 2006 | 11:19 PM
Sounds good hope it works well.
Jat007
Jul 19, 2024 07:41 AM
ded137t5r
Jun 10, 2012 07:40 PM
612diablo
Jun 12, 2008 09:11 AM
Shaun Oriold1
Oct 5, 2006 11:56 PM
Volvo240guy
Jul 31, 2006 12:53 PM
